Wheel question
- Colorado Mike
Wheel question
Is a 2003 wheel the only one that will fit the '03 forks?
I have an 01 on my 03 forks.
- Colorado Mike
so, I have '03 forks, '03 axle and spacers, plan to use my '04 KDX brake. Think that'll work with an 01 wheel, or is it a try and see type thing? I guess what I'm really asking is what is the determining factor on what model years of wheels will work with these forks. Is it the hub? If so, then I could just see when the part number changed for the hub on different years, on the parts listings.
Thanks,
Thanks,
- Has thanked: 190 times
-disclaimer-
I am NOT saying ANYTHING fits ANYTHING
-end disclaimer-
If you check aftermarket parts in addition to buykawasaki.com part numbers, you may find what years fit what years better.
Download the "wheels" section from the Tom & Dan catalog.
-end disclaimer-
That should work.
I can only say for sure for what I have.
- Colorado Mike
http://www.whitebrothers.com
Tom and Dan White have had White Brothers for 25?? years or so. Each section of the catalog is in PDF format. Download the "wheels" section. Whatever section(s) of the wheel catalog I was looking at led me to believe that 1999 - 2003 will interchange, as far as wheels go. That may not mean the axle, though. Again,
-disclaimer-
-end disclaimer-
Well, besides triple clamps and forkses, 'cause I know a lot about those.
-disclaimer-
-end disclaimer-
- Colorado Mike
That would be a 01 axle with 03 spacers... I have the 01's and they look identical...
