Air filter oil and cleaner?
bored808
Post by bored808 »
What is everyone using as an air filter cleaner and oil?
Back in the day I used to use gasoline but now a days it's more difficult to get rid of.
s10gto
Re: Air filter oil and cleaner?
Post by s10gto »
Any bike shop will carry both cleaner and oil. Imho any name brand will do. The spray cleaners work well.
Bitteeinit
Post by Bitteeinit »
I use no toil. Seems to work ok but I'm always unsure as to how much I should be putting on. Also, I tore a bit of my filter because is had fused with the screw... Maybe I hadn't let it dry a full hour, I don't know. But overall I'm satisfied.
jerry malbeck
Post by jerry malbeck »
Simple green works really well so does dawn dish washing liquid .rinse well let dry and spray with belray filter oil , Or a tub of filter oil , I prefer the spray, rub in till all the filter is the same color. If you use a tub you will have to damp out the filter( remove excess) , do not wring it out as it may rip the foam .
Bitteeinit
Oh yeah, forgot to say: I use oxyclean to clean my no toil filter. Works great and is fairly cheap.
Has thanked: 194 times
Been thanked: 51 times
Kerosene a few times, then warm water/Dawn a few times, then cold water rinse a few times.
Been thanked: 19 times
I use a two step process. Soak the filter in a bucket of Varsol, that gets the old oil out. Then dunk in a tub of simple green to get the varsol out and whats left of the dirt. Rinse with water and I'm left with a squeaky clean filter, every time.
6 Riders
Post by 6 Riders »
Slick_Nick wrote:I use a two step process. Soak the filter in a bucket of Varsol, that gets the old oil out. Then dunk in a tub of simple green to get the varsol out and whats left of the dirt. Rinse with water and I'm left with a squeaky clean filter, every time.
Hmm, where would I find "Varsol"?
Any hardware store has it. It's basically paint thinner.
Bitteeinit
It doesn't mess up your filter? Varsol is really strong. Often used in the oil industry as well as a cleaning agent for weapons caked in carbon...
jerry malbeck
Oxyclean on a no toil, Awesome i wondered what would cut that stuff.
Bitteeinit
Yeah I did some reading online on what the active chemicals were and a few people seemed to also use oxyclean (which has the same chemical) on thumpertalk. But either way, I can confirm it works great. Most people just throw it in the machine, but I put half a scoop in a bucket of water, then let it soak for 5 mins and wearing gloves, work it over as you normally would. Gets all the dust and no toil out great.
Oops. I did not put what oil. I have had great luck with Bel-ray and Maxima oils. I prefer oil, not a spray.
