the splines look bad and the shifter, not much better on the shaft.
is there a guide to replacing the shifter shaft?
shifter stripped, fix?
ohgood
- gsa102
Re: shifter stripped, fix?
On most full size bikes you have to remove the clutch basket and the shift shaft pretty much just pulls out from behind it. Should have a spring to hold it in the neutral position that you will have to remove as well. Also a good time to change the seal.
96 KDX 200, 09 YZ 250
ohgood
gsa102 wrote:On most full size bikes you have to remove the clutch basket and the shift shaft pretty much just pulls out from behind it. Should have a spring to hold it in the neutral position that you will have to remove as well. Also a good time to change the seal.
man I hope so, going to check the parts fiche
- Tedh98
- Been thanked: 2 times
- diymirage
A semi fix might be to take a grinder to the shifter and cut the opening out a little more, that way when you tighten the bolt it tightens up better
ohgood
already did, and then tried red loctite on both the splines and boltdiymirage wrote:A semi fix might be to take a grinder to the shifter and cut the opening out a little more, that way when you tighten the bolt it tightens up better
JasonK94Z
The bike is worth the fix. Will make a nice project and maybe a good time for some other maintenance as well.
Just trying to put a positive spin on it for ya.
2002 KDX 220R
2003 KLR 650
2003 KLR 650
newbbewb
you CAN place a tack weld onto the very end of the shaft then move over to your shifter. you can either grind the weld off to get your shift lever back or just plasma cut the whole mess off when your ready to change the shift shaft. not recommended but it does work very well.
- diymirage
newbbewb wrote:you CAN place a tack weld onto the very end of the shaft then move over to your shifter.
don't let the mods see that advice, they will take one of your stars away
