Question
Fatherof2
Question
Post by Fatherof2 »
Shot in the dark but....... if anybody knows it'll be one of you guys!
Have an '81 KDX175 and the rear shock is not rebuildable and weighs a ton (though that's neither here nor there)
I picked up an '81 KX125 shock which has the remote reservoir and weighs about 1/2 what the KDX one does. It's also rebuildable, which was my main issue in this endeavor- as well as being a much better shock.
I also snagged the swingarm from that same KX and was wondering if anybody knows whether or not that will fit on the KDX?
The dimensions look the same. The KX one is aluminum- the KDX one is steel.
It looks like the shocks are interchangeable and I'm hoping arm is, as well.
All linkages are the same so......
Just curious about the arm and if anybody has any experience with this or similar.
For God and Country......Geronimo, Geronimo, Geronimo!!
Re: Question
IF the linkages are the same, and the shocks the same length, then the last piece of the puzzle is the swingarm length and pivot bolt diameter. If it is within a few mm of each other in length then should be no problem swapping them, but have never done it.
Has thanked: 160 times
Been thanked: 40 times
Re: Question
I will not help, but blindly guess (somewhat educated guess).
The KX swingarm will be longer. The KX shock will be longer. It has to have some way to have more travel.
adam728
Re: Question
Post by adam728 »
Jason wrote:I will not help, but blindly guess (somewhat educated guess).
Did the KX have more travel than the KDX that year?
