no sparks
zed1
no sparks
hi folks , totally out of ideas now , was out on the bike a few weeks ago when she just died on me ,swapped plugs still no go but after leaving for a while to cool down fired up but only ran for a minute or two then cut out again , bit of investigating and it seemed to be stator needed rewinding so had it done ,got bits back put stator back on fired her up ran for a minute then stopped since then nothing swopped coil/lead ,ht cap ,plug and today cdi unit and still no spark ,I've disconnected all lights(they were fine but just incase) the kill switch and ignition switch to try to eliminate any possible shorts .now as I say not a clue what to do so any and all ideas welcome cheers
superman27e
Re: no sparks
Make sure all your grounds are clean and the frame sanded and clean where it bolts to.
