2T oil or grease
Dekon
2T oil or grease
So I am going to be rebuilding the bottom end and someone told me to put some grease on the new crank bearings(actually all the bearings in the case). I thought you just needed to put some good old 2T oil on them. I use Torco GP7 and that is what I was going to put on the crank bearings. All the other bearings and the bushing in the case(I am replacing them while the cases are split) I was just going to put ATF Type F on them as that is what I am switching to after the rebuild. What is everyones opinion on this?
- Has thanked: 195 times
- Been thanked: 52 times
Re: 2T oil or grease
GREASE?? I would just do what you said, 2-stroke oil in the crankshaft / piston area and transmission oil in the clutch / transmission area.
KDXrider1989
what Jason said, I wouldn't use grease on any internal motor / tranny component
Dekon
2T oil or grease
Thanks guys, that is exactly what I thought. He claimed a little grease packed in the bearings was better for the inital start up.
tirebiter
2T oil or grease
I use what ever 2 stroke oil I'm running on the crank side, assembly lube on the trans side.
If I can't do it, I'm sure someone else can!
- ss109
- Has thanked: 33 times
- Been thanked: 57 times
2T oil or grease
The factory service manual says 2T oil. I personally wouldn't want my fresh engine trying to burn grease!
