92 KDX airbox elimination?
Railinandnailin
Post by Railinandnailin »
Is it possible to remove the airbox all together and replace it with a pod and cover? I want to install a battery into the electrical system and there is really no way to do this because of space. Is there any other option to do this? I want to be able to ride trails with no problems.
Re: 92 KDX airbox elimination?
What is the reason for adding a battery? There are several options to create street legal wiring on your KDX and still retain your airbox. Baja Designs makes a complete kit for the conversion. Another method is here http://www.kdxrider.net/forums/viewtopi ... ry#p143330.
Railinandnailin
bufftester wrote:What is the reason for adding a battery? There are several options to create street legal wiring on your KDX and still retain your airbox. Baja Designs makes a complete kit for the conversion. Another method is here http://www.kdxrider.net/forums/viewtopi ... ry#p143330.
I already have everything i need for a conversion, I found the baja designs to be a little pricey for my budget. Im running a front headlight, rear tail light, horn, turn signals front and rear and any other accessories i want to add in the future. How easy are those batteries to add stuff like one with terminals. I already have a battery which is about 4.5x4.5x3
Fitterman24
Post by Fitterman24 »
I suppose you could put a pod air filter on and put a battery in the stock air box. I'm guessing this is only a street bike. Either way, I'd install a 'outerwear' cover over the pod as I think they are somewhat water resistant if you get caught in the rain.
capnbluetootharr
Post by capnbluetootharr »
removing the air box is a very bad idea especially if you want to ride trails .what about a smoothing capacitor rather than a battery ? the battery you have is big enough for a Harley . if you really need a battery choose a smaller one that fits in the air box.
Railinandnailin
capnbluetootharr wrote:removing the air box is a very bad idea especially if you want to ride trails .what about a smoothing capacitor rather than a battery ? the battery you have is big enough for a Harley . if you really need a battery choose a smaller one that fits in the air box.
So is there any suggestions on a mounting location for this battery? Or possibly a link to this capacitor and some info. I made a battery box that mounts on the triple trees but im unsure about safety and it gets in the way of my light.
capnbluetootharr
in systems that are designed to work with a battery a smoothing capacitor can be used in place of the battery if the battery is removed . it only works while the motor is running .in my experience on my KTM the lights and blinkers a much brighter at idle with the smoothing cap installed .my bike already had the plug for the smoothing cap installed so it was easy for me .I just used a old smoothing cap from a 92 KDX 250 Australian model. it was behind the right side plate . cylindrical about 2" long and 1" dia with 2 wires .
