Will 92 KDX 250 rear wheel fit a 92 KDX 200?
jreibson
Post by jreibson »
I have a '92 KDX 200E. I'm in the process of rebuilding it and need a new rear wheel because the one on it is very badly bent. Can I use a '92 KDX250 rear wheel without modifying it?
Thanks!
capnbluetootharr
Re: Will 92 KDX 250 rear wheel fit a 92 KDX 200?
Post by capnbluetootharr »
The 250 has10 mm larger diameter disc rotor & the disc mounting bolts are also bigger than the 200.you will need to mod the 200 disc or the mounting bolts . Then it should fit .the PCD is the same
jreibson
Post by jreibson »
That's exactly what I wanted to know.
Thanks so much for the info.
This bike was a mess when I got it and we put lot of parts and time into it. Now my 17 yr old son is having a great time on it.
It's not real snappy yet but I'm adjusting the carb and swapping jets. I also added the Fredette torque ring and that really helped the bottom end.
Thanks again for your help!
