found shorter bolt for front brake lever
canamfan
Kawasaki part # 92150-1451 replaces the long bolt on the brake side made for handguards that comes on the h series. fits perfectly Won't work on the clutch side.
SockswithSandals
Re: found shorter bolt for front brake lever
Any other information on lever bolts that work for the front brake and clutch levers? Was hoping the clutch lever mounting bracket was the same across KDX and KX of the same model years so the KX lever bolts could be used, but the last four digits of the KX mounting brackets are different. Love to dump the stock bolts after getting rid of the mud guards.
