2003 KDX 220.
Little by little, I'm making my bike dual sport. I want it fully functional for road use, but I'll use it on the road >1% of the time. It's time to upgrade my stator I think. I installed a horn a while back but discovered the bike doesn't have enough juice to run the horn unless I really rev my bike up. Right now I have the stock headlight and taillight with an LED stop/tail light that is cut down and mounted underneath the fender. My plan is to switch out the headlight to a KLX style headlight. I also still need to put the blinkers on it. When it's all said and done, EVERYTHING will be LED.
SO If I go LED with an 85 watt stator from Ricky Stator, I think I'll have enough juice to power my horn, headlight, taillight, blinkers, and a Trail Tech. But with the LED's not pulling the same draw as the normal incandescent bulbs, will there be too much juice and ruin bulbs/wires when the horn is not on?
Need To Up Grade Stator: Questions
morganid
- Has thanked: 10 times
- Been thanked: 12 times
You'll be fine.
- diymirage
Re: Need To Up Grade Stator: Questions
you can get as good (if not better) a power output by rewinding the stator yourself at a fraction of the cost of an aftermarket one
there is a thread about it somewhere on here...
- K50X200
+1...diymirage wrote:you can get as good (if not better) a power output by rewinding the stator yourself at a fraction of the cost of an aftermarket one
"00 KDX200 - Baja Designs D/S Kit, '03 KLX300 Forks, KB5 Suspension Mods, Keihn 35 ASQV, Boyesen Rad Valve, Gnarly Woods Pipe
- adam728
It will only put out the power drawn from it. A 250 watt lighting coil isn't going to push 250 watts through a 5 watt bulb.
That said, you may still be disappointed if you set your hopes too high. An 85 watt coil is 85 watts at some rated rpm, not idle. It might only push 20-30 watts at idle rpm. My bike ended up with a stock headlight, LED tail/brake light in the factory housing, and little 3W blinkers. At idle it would nearly turn the headlight off when the blinkers would try and light. Keeping a toe on the brake light meant there wasn't enough voltage to even click the flasher for the blinkers.
pumpguy
Just curious, was this output with a stock lighting coil, or something better. If better, what would you estimate the wattage output is?
- adam728
Sorry, I meant to say that my bike had an upgraded coil, and "85W" Moose branded one.
