heavy springs
capnbluetootharr
heavy springs
T he stock fork and shock springs in my 89 200 f / sr are too soft . Do the 89 E series springs fit ?
- Has thanked: 191 times
Re: heavy springs
The stock 1989 E series springs are .30 Kg/mm rate. They are SUPER SOFT!!!
capnbluetootharr
Re: heavy springs
Racetech dont list SR springs. If I order E series springs will they fit o n the SR shock and forks .
Re: heavy springs
What forks are on a 1989 KDX200F?? We don't have that in the USA.
capnbluetootharr
Dodger
heavy springs
I have Eibach series 996 springs in my SR forks - this link shows which bikes the 996 series fits.
http://www.ebay.com/itm/Eibach-Fork-Spr ... 1055136072
You just need to work out the spring rate for your weight and also you have to cut down the fork preload spacer as these springs are longer than the OEM springs.
Cheers.
Cheers.
I may be old, I may be slow, but hey I'm still getting my leg over - a dirt bike!
capnbluetootharr
- 6 Riders
Re: heavy springs
The stock oil is 5wt, but most fork builders would recommend 7wt oil in the KDX forks.capnbluetootharr wrote:Thank you Dodger .what weight oil are you running ?
Dodger
Re: heavy springs
10w - I also have Race Tech Cartridge Emulators in the forks. I think the Emulators made a difference but as I fitted them 14 years ago, I've forgotten what the original damping felt like!capnbluetootharr wrote:Thank you Dodger .what weight oil are you running ?
Cheers
Re: heavy springs
I think the stock oil on the conventional forks is 10 weight, with 5 weight on the cartridge forks.6 Riders wrote:The stock oil is 5wt, but most fork builders would recommend 7wt oil in the KDX forks.capnbluetootharr wrote:Thank you Dodger .what weight oil are you running ?
