KDX200 Wiki
- Gotanubike
KDX200 Wiki
Hey guys, well from day one i always wondered why there was no wikipedia page written for the KDX200. So today I began to write a KDX200 wikpedia page article in their designated sandbox area for beginner writers. Before I knew it, I had something worthy of publishing as a legitimate article!
Here is what I have so far
https://en.wikipedia.org/wiki/Kawasaki_KDX200
As you will probably find there may be some inaccurate info there, I tried to go by what I found in random articles relating to the KDX, and from any info I have learned already.
If you think anything can be changed, anything you'd like to see added to the article, either let me know ASAP, or you can register with wikipedia for free and edit the article yourself!
Much of the formatting, such as the table charts and picture embedding formats I borrowed from other articles.
Some info that would greatly be appreciated are the following:
- Any notes regarding changes to revisions of A, C, E and H models
- Specifications for EACH generational revision, using the list below...any info you believe to be not available for the KDX model can be removed:
A model:
Engine Type Single-cylinder, air-cooled, two-stroke
Carburetion 34mm Mikuni carb
Displacement 198cc
Bore × Stroke 66.0 x 58.0 mm
Compression Ratio 7.7 : 1
Fuel Capacity 12.5 Litres
Oil Capacity 0.7L / (0.74 US qt)
Seat Height N/A
Dry Weight 101kg
Tires Front: 80/100-21 Back: 110/100-18
Brakes Front: Single 221mm disc Back: 110mm drum
Final drive 6 Speed / chain
C model:
Thanks Kawagumby for the info!
engine type: 2-stroke, single cylinder, piston reed valve
Carburetion Mikuni VM34SS
Displacement 198 mL (12.08 cu in)
Bore × Stroke 66.0x58.0 mm (2.60 X 2.28 in)
Compression Ratio 7.7:1
Fuel Capacity 12.5L (3.3 US gal)
Oil Capacity 700 mL (0.74 US qt)
Charging System Output (not shown)
Seat Height (not shown)
Dry Weight 101 kg (223 lb)
GVWR (not shown)
Tires 80/100 - 21 51M (front), 100/100 -18 59M (rear)
Brakes Front: Disk brake diameter 220 mm (8.7 in)
Rear: Internal expanding, leading trailing 110X30 mm (4.3X1.2 in)
Final drive 3.692 (48X13)
E model:
Engine Type Single-cylinder, liquid-cooled, two-stroke piston reed valve
Carburetion Keihin PWK-35
Displacement 198cc
Compression Ratio 7.7:1 (high speed) 9.2:1 (low speed)
Fuel Capacity 12.0L
Oil Capacity SAE 10w30 or 10w40 0.75L
Seat Height 910mm
Dry Weight 102 kg
Tires(tube) Front: 80/100-21 51mm Back: 100/100-18 59mm
Brakes Front and rear: single piston; disc
Final drive Chain drive; 3.625(47/13)
H model:
Engine Type Single-cylinder, liquid cooled, two-stroke
Carburetion Keihin PWK35
Displacement 198cc
Bore × Stroke 66 x 58 mm
Compression Ratio 9.4:1
Fuel Capacity 11 Litres
Oil Capacity 0.75L
Seat Height N/A
Dry weight 109 kg
Tires Front:80/100-21 Back: 100/100-18
Brakes Front: Single 250mm disc 2 piston caliper Back: Single 230mm disc 1 piston caliper
A model:
Displacement 198cc
Seat Height N/A
Dry Weight 101kg
C model:
GVWR (not shown)
E model:
Displacement 198cc
Fuel Capacity 12.0L
Seat Height 910mm
Dry Weight 102 kg
H model:
Displacement 198cc
Oil Capacity 0.75L
Seat Height N/A
Dry weight 109 kg
1990 KDX200
- kawagumby
Re: Help needed! Started a wikipedia page for the KDX200 tod
Here are the KDX 200-C1 model spec's from the Kawasaki Motorcyle Owners Manual and Service Manual (1986)
GVWR (not shown)
Front suspension stroke 270 mm (10.6 in)
Rear wheel travel 290 mm (11.4 in)
the 1988 C models had some changes including a different carb and a minor internal clutch setup. Maybe someone with the exact upgrades/changes can chime in.
GVWR (not shown)
- Gotanubike
Help needed! Started a wikipedia page for the KDX200 today!
Excellent...I was able to fill in E series specs from info in my manual..Will go ahead and fill in the C specs now. thanks
1990 KDX200
- Gotanubike
Just need someone who can copy over the info from their H series manual, and someone who has the Specs for the A model, which I assume is more less the same as the C anyways...
Any more Sub-content information such as VIN identification could be included.
open to all suggestions
1990 KDX200
Updated the description of the E-Series photo caption to indicate that it is a 1993 (not a 1992). (Filename still infers 1992, though).
Also main image for page is not an E series, but an SR. Don't know what year though. I guess an SR section to the article may be needed.
Just had a look. Nice Job!
Sthutch
1st Bike: '72 Arctic Cat Whisker (rode it to the wheels fell off)
2nd Bike: '76 KT250 Trials (gone, but not forgotten)
3rd Bike: '01 KDX200
4th Bike: '96 DS80 (okay, my 9yr old's and it's gone)
5th Bike: '04 RM65 (okay, he's now 10 and it's gone)
6th Bike: '08 KTM 105xc (okay, he's now 13)
7th Bike: '06 KTM 200xc-w (okay, he's now 16)
- Gotanubike
Thanks sarrant...Throw me a quick definition of "SR" and what models are givin the SR title and I will add it to the notes for the relevant models. I've only seen E series SR models, from what I know they are only non - N American models?
1990 KDX200
- Gotanubike
I've gathered quite bit of info and everything is in place. All I need are A series specifications
1990 KDX200
Great job! I hope you find the rest of the info!
- Gotanubike
Just a few mere things for the 83-85 models
1990 KDX200
- 6 Riders
seems the stroke on either the E or H is wrong.....the E is listed as 58, the H as 85......
- Gotanubike
Ah good eye, that would be a typo on behalf of motorcyclespecs.co.za where I got the H specs
http://www.motorcyclespecs.co.za/model/ ... 0%2098.htm
1990 KDX200
- Gotanubike
KDX200 Wiki
I think I have all the tables and most revision notes filled in...any input regarding misinformation, incorrect info, or any more more subjects that could be added regarding the kdx200 would be appreciated...
As for the SR models, I have only been able to find small amounts of info on 89-94 series SR models, but have seen pictures of SR H models in the past...I want to try and be as clear as possible and provide the most info I can
1990 KDX200
KDX200 Wiki
It seems me the real name for " "E" series SR" is G serie ;)
i'm French and I don't speak English very well, so, please, excuse me :)
Re: KDX200 Wiki
Excuse me i'm not an expert but it seem me it is a mistake on the wiki : the 94 model have a 41 kayaba usd as the 93 and not a 43 ...250 KDX has the blue 43 usd ( not the the same as KX 93 : less of possible settings )
- Gotanubike
KDX200 Wiki
You may be right, thanks for the input. Jason did point out in another thread that they are known by B, D, F, and G in some countries...I did label the charts as U.S models only, perhaps I should add something to the descriptions...
As for the forks, the info I gathered for that was from cyclepedia.com. See here for year 1994..
http://www.cyclepedia.com/kawasaki-kdx200/
1990 KDX200
Re: KDX200 Wiki
I'm not pretentious enough to know better than that Cyclepedia, but as you can see the OEM numbers of the fork seems the same in 93 and 94
http://www.kawasakipartshouse.com/oempa ... x200-e5-e6
- Gotanubike
KDX200 Wiki
Thanks for that...they might have mixed it up it with the kdx250 around the same year which had 43mm USD's. Forks are something I have yet to fully explore...
Appreciate the tip
Appreciate the tip
1990 KDX200
Re: KDX200 Wiki
happy to help!
Re: KDX200 Wiki
Good luck on your wikipedia efforts.
I the USA, 1993 and 1994 KDX200 had 41mm USD inner tube forks. 1991 - 1994 KDX250 had 43mm inner fork tubes.
You may be able to find some information from ...... Kawasaki!
http://www.kawasaki.com/DefaultFrame.as ... EHTABS%3d1
Also, buy the model identification CD from Kawasaki for 1965 - 2001 models. It shows all the B, D, G, SR, USA, EU, UK, AUS, etc. models. 99969-0896-01 , about $11
