2002 KDX 200 Fork Oil Air Gap
Rooks
Post by Rooks »
Changing out the front springs on a '02 KDX200 and was wondering what the nominal air-gap measurement is for these forks (as measured with no spring/fork fully compressed)? I've seen several posts mentioning oil volume...but have always preferred using the air-gap measurement...so I figured I'd ask.
Thanks in advance for your help.
tirebiter
Post by tirebiter »
I'm running 120mm down, seems to work just fine. Using 5wt right now, but thinking about switching to 7.5 for a little more rebound..
If I can't do it, I'm sure someone else can!
JasonK94Z
Post by JasonK94Z »
tirebiter wrote:I'm running 120mm down, seems to work just fine. Using 5wt right now, but thinking about switching to 7.5 for a little more rebound..
Going up in oil wt actually slows down rebound.
2002 KDX 220R
2003 KLR 650
MCKDX220
Re: 2002 KDX 200 Fork Oil Air Gap
Post by MCKDX220 »
I am currently at 130mm, no casing, 4 compression hs valve shims removed from each leg. .41 springs.
The recommendation in the manual is 100mm, which if I ran the stock compression valving and springs, that is what I would run.
Michael
87 KDX200 / 02 KTM 520 EX/C / 87 XR 200 / 90 XR 200
tirebiter
Post by tirebiter »
Well duh, that's what I stated...
More rebound equals slower, unless your from down under, then lord knows what's up or down..
Rooks
Post by Rooks »
Thanks so much for the replies. I'll start at 100 and take things from there.
motogoalie1
Post by motogoalie1 »
Im at 130 mm from top per race tech. Im also sporting .41kg xr 600 springx
hsracer1962
Post by hsracer1962 »
to tirebiter. Mr well duh, your statement is in print you cant deny your error so just apologize and move on.
tirebiter
Post by tirebiter »
hsracer1962 wrote:to tirebiter. Mr well duh, your statement is in print you cant deny your error so just apologize and move on.
JasonK94Z
Post by JasonK94Z »
There always has to be that one guy ... :roll:
2002 KDX 220R
2003 KLR 650
Joshmcmillan
Post by Joshmcmillan »
I think you two just had a mix up of words but were both implying the same thing.
To OP, sounds like 100mm is the way to go.
07' CR450X (Main Bike)
91' CBR250RR
motogoalie1
Using adjectives and adverbs can clarify ones meaning.
faster rebound action
or
less rebound damping
slower rebound action
or
more rebound damping
and stuff :boogie:
Has thanked: 195 times
Been thanked: 52 times
tirebiter, maybe everyone does not use the same language as you.
Also, no need for misspelled foul language. :?
hsracer1962
Rooks wrote:Thanks so much for the replies. I'll start at 100 and take things from there.
no you are wrong, more rebound means quicker.heavier viscosity oil / 7.5 vs 5 would result in slower { LESS } not more { quicker }. Well DUH so ends your lesson for today.
Your lesson is "welcome to forums", also known as "you replied to a message from 10 months ago" :grin:
Do try to be mindful of the dates.
