Whats the difference in models?
emk
Post by emk »
I'm looking at a 92' for my son. The thing looks really clean. What is the difference in the model years and what do you look for in the vin to see if you could tag it? Are the plastics interchangeable throughout all the years?
Has thanked: 52 times
Been thanked: 18 times
Re: Whats the difference in models?
Tag depends on your state laws. Most don't allow it.
Here is some info I compiled:
List of KDX Models, along with some model variation information: This information applies to USA models.
1979
KDX400-A1, first KDX model introduced
1980
KDX80-A1 introduced
KDX175-A1 introduced
KDX250-A1 introduced
KDX400-A2
1981
KDX80-A2
KDX175-A2
KDX250-B1
KDX420-B1, KDX400 goes to KDX420
1982
KDX80-B2
KDX175-A3, last year for KDX175
KDX250-B2
KDX450-A1, KDX420 goes to KDX450, last year for KDX400/420/450
1983
KDX80-B3
KDX200-A1, first year for KDX200
KDX250-B3
1984
KDX80-C1
KDX200-A2
KDX250-B4, last year for the air-cooled KDX250
1985
KDX80-C2
KDX200-A3
1986
KDX80-C3
KDX200-C1, front disc brake, power valve engine, 43mm conventional forks
1987
KDX80-C4
KDX200-C2
1988
KDX80-C5, last year for the KDX80
KDX200-C3, available with lime green frame and lime green plastic or silver frame and white plastic, last year for air cooled full sized KDX
1989
KDX200-E1, heavily redesigned with liquid cooled engine, rear disc brake, different frame, improved suspension, etc.
1990
KDX200-E2, available with lime green frame and plastic or sky blue frame and white plastic
1991
KDX200-E3, last year for KDX200 available with lime green frame and plastic or sky blue frame and white plastic
KDX250-D1, KDX250 reintroduced with perimeter frame, liquid cooled engine, USD forks, rear disc brake, etc.
1992
KDX200-E4, last year for full sized KDX with damping rod forks
KDX250-D2
1993
KDX200-E5, KDX200 receives upside down (USD) forks, 41mm inner tubes
KDX250-D3, change to full floater front disc rotor
1994
KDX200-E6
KDX250-D4, last year for KDX250
1995
KDX200-H1, KDX200 totally redesigned with perimeter frame, conventional forks, engine, brakes, shock, etc.
1996
KDX200-H2, various parts in violet (purple)
1997
KDX200-H3
KDX220-A4, KDX220R released, almost entirely the same as KDX200, engine bore size larger, o-ring chain
1998
KDX200-H4
KDX220-A5
1999
KDX200-H5
KDX220-A6
2000
KDX200-H6
KDX220-A7
2001
KDX200-H7
KDX220-A8
2002
KDX200-H8
KDX220-A9
2003
KDX50-A1, KDX50 released (as part of Kawasaki - Suzuki alliance)
KDX200-H9, change from lime green frame to gray/silver frame
KDX220-A10, change from lime green frame to gray/silver frame
2004
KDX50-A2
KDX200-H10
KDX220-A11
2005
KDX50-A3
KDX200-H11, frame color changed to silver, lighter lime green plastic
KDX220-A12, frame color changed to silver, lighter lime green plastic, last year for KDX220R
2006, last year for all KDX's :-(
KDX50-A6F
KDX200-H12
Gotanubike
Post by Gotanubike »
In a nut shell, 89-94(E1-E6) are all the same models with intercompatible parts....then 95-06 took on the letter "H"(H1-H10?). The main difference being the upgrade to the KIPS powervalve system in the H models. Very few parts are interchangeable between them I think. Some things are direct swaps such as the kx250 forks I believe and some other stuff, I'm still pretty new to them too
1990 KDX200
Keystone
Post by Keystone »
http://kdxrider.net/forums/viewtopic.php?t=10209 Found a thread discussing differences between E and H.
emk
Post by emk »
Thanks for the info guys
