kx 500 surging
kx 500 surging
Hello all.I don't post much but I do alot of reading on this site and it is very helpful.I have been given a 1992 kx 500 I got i running but when i ride it it runs fine 3/4 throttle or so and when I let off the throttle still in gear it surges.Any help would be great never had one do this before.
- 6 Riders
Re: kx 500 surging
Explain "surges"...goes faster? The throttle doesn't release?
- 6 Riders
Re: kx 500 surging
sounds like the needle is sticking. Clean the carb up and see what happens.
kx 500 surging
Could be an air leak at the reed cage gasket or possibly the crank seals. I had a 88 KX500 that had a air leak at the reed cage and it would surge/run on when letting off of the gas. My 04 KX250/500 hybrid doesn't do this and runs near perfect.
Re: kx 500 surging
Thanks I have been planning to check for air leaks when I get time.I read on the kx forum that it is common for the kx 500 to surge like this.I don't like that.The 500 and I will part ways if I can not stop it.
Re: kx 500 surging
You can also try to turn the air-bleed screw in. My YZ would surge when off throttle and idle. Turned it in a 1/8 a turn and was fixed. If it helps but doesn't fix it make sure the pilot jet is super clean. Good luck!
