Newbie from Ma.
Newbie from Ma.
Hello eveyone! Names Dustin. New to the KDX family with a 220. Found this forum and love it. Currently riding a 98 YZ250 with Gnarly pipe , FMF silencer and V-force reeds. Not bad in the woods but thought I would try a real woods bike. Looking forward to some goood reading to get through the winter.
- diymirage
Re: Newbie from Ma.
welcome aboard dustin
that's actually a pretty good name cos with a well set up KDX you will be dustin every other bike on the trail
your main priority right now would be figuring out if your bike has a stock piston in it or not because if it is you will need to replace it
if it is already running a forged piston you should focus on dialing in the suspension for your weight
Re: Newbie from Ma.
Thanks diymirage. It is stock. Found this bike with only 10 hours on it. Its like new. How long can you trust the stock pistons? Thanks
- diymirage
Re: Newbie from Ma.
The only way to tell how long you trust a stock 220 piston is run it till it breaks and then minus a couple of hours from that
Im not sure what causes it but they tend to develop fractures in the skirts and drop them
If your lucky this destroys the topend...if your not so lucky the debris takes out the bottm end aswel and you will need to split the cases to fix it
- turtle
Re: Newbie from Ma.
Welcome, Dustin! +1 on what DIY said. Definitely replace it as soon as you can. My 220 has scars (welded up holes) in the bottom of the case from such a failure - fortunately (?) before I owned it. Otherwise this thing is pretty bullet proof.diymirage wrote:The only way to tell how long you trust a stock 220 piston is run it till it breaks and then minus a couple of hours from that
Bill
Central IL
2004 KDX220R
2011 Triumph Tiger 1050 SE
Central IL
2004 KDX220R
Re: Newbie from Ma.
Thank you guys. I will replace it. Better safe. Its almost winter anyways and the 250 is going strong for the rest of the season.
Thanks again
Thanks again
