I'm new here. Over here in the UK we have a reasonable Vinduro thing going on and I've just bought a very cheap and pretty original red 84 KDX200. There are a few parts missing; headlight, left side panel, air-box cover, carb, flywheel, stator and flywheel cover. I did get two CDIs with it - not that they'll be a lot of use I suspect.
The bike looks like it was ridden pretty gently back when it was new and then got laid in the sun for the next 25 years. The parts that usually show a hard life like worn footrests, linkages, lower frame rails and so on are all good so if I can figure a flywheel/stator solution it'll get fixed up and ridden.
And so; has anyone fitted the later flywheel to the 84? Or does any other flywheel fit on there? If I can get a flywheel on I can figure the stator but any tips on that would be appreciated. I don't need a lighting stator or even an external rotor - just something that'll get the bike working somewhere near decent.
I've checked the crankshaft part numbers and the 83/84/85 is different from the C models (which I know will take an E/H flywheel) but is the difference just the weight or is the width and/or taper different on the left crank half?
How's the pipe/silencer situation with the A models? The stock one is pretty good and I can fit a newer silencer no problem - I have cutting & welding gear.
Has anyone done or seen a twin shock conversion? I'm tempted to do it but any knowledge is always good - even how not to do it.
A final question. In the UK we didn't get the red bike so spare plastics are even more difficult to get hold of than in the USA. Should I put the (pretty good condition) plastics on a shelf and find some green stuff to use for riding? I know it's hard to believe but over here in the UK with us being almost as far North as Alaska we do sometimes get a bit of rain and some muddy riding
I'll no doubt be back again and again asking for more information, anything anyone can add will be good.
