HELP: KLX fork swap question
Comp721
So I just got done putting some KLX 300 forks on my DX and everything is great except there is a little bit of "wiggle room" on my front wheel. As in it can be pushed side to side. Can anyone shed some light on what may be wrong? TIA
- KDXohio
Re: HELP: KLX fork swap question
Check that the axle but is fully seated with the holders loose
zepplin153
Its ruined! I guess you will have to dispose of the bike. I can take care of it for you
Kidding. just check you have all the axle stuff in there correctly. there are some spacers that go in between the fork end and the axle. check a parts diagram (tons available, but easy to find on thumpertalk.com). could also be your bearings, doubt it but just check.
'98 KDX 200 (KLX300 Forks)
