Sorry I couldn't find the answer
what size is the circlip that holds the front sprocket on? Ive bent it a little getting it off and thought best to put a new one on when the new sprocket goes on and couldn't see what the size of it is!
many thanks
si
probably a silly question!
- Been thanked: 10 times
Re: probably a silly question!
24mm
Mine was bent a little last time (so it kind of had the shape of a lock washer) and I just reused it and it has been fine. If it's bent so that the diameter has changed then you should replace it.
ukkdx200
ahh ok thanks,bufftester wrote:24mm
the diameter hasn't changed but I think for the sake of about £1 I will get a new one
Thanks for your help!
si
