89 kdx 200 in a 89 kx125?
junkman
Post by junkman »
hi I have a 89 kdx200 just rebuilt top and bottomend I been riding it for about 3 months and has been doing good until last Monday :mad: I was going down some power lines in 2 gear wasn't going fast I was wait for some friends to catch up and suddenly it bogged down and seized up and throughout the day the bottomend was getting louder louder .. and when I got the bike it was blown up and the crank bearings needed to be replaced because well they were bad and when I replaced them the one side bearing (I think the clutch side) was like totally gone it was only 3 balls and the 2 racists so the question is is my crank outa wack or something cause the crank bearings were brand-new so if you could help me out with that ...next question I saw a 89 (same year as the kdx) kx 125 for 100 bucks the guy says it needs 1 gear replaced but can I put the gears from the kdx into the 125 the motors look the same ? let me know .. and also going with that question are the motors same like can I bolt the kx motor up into the kdx frame with no problem and can I put the bottomend of the kx and put the kdx topend on it let me no all info will be help thanks,dustin
sarrant
Post by sarrant »
Engines share very little in common and are not interchangeable, parts or in whole. Chassis & some of the plastic is of a common lineage, and some of that are bolt-on swappable.
junkman
Re: 89 kdx 200 in a 89 kx125?
Post by junkman »
thanks for the help I was actullying going to go get it today thanks man!
junkman
Post by junkman »
so does only a 89 kdx 200 motor fit in it or will a different year kx 125 or 250 fit in it .. just so I know what to look for as in on craiglist
sarrant
Post by sarrant »
Only thing I know of that will just bolt in is 89-94 KDX 200.
Has thanked: 160 times
Been thanked: 40 times
same here
junkman
Post by junkman »
ok thanks saves me a head ace :supz:
KDXohio
Post by KDXohio »
Just fix the one you have!
