Question on KLX fork swap
Dekon
Post by Dekon »
Quick question, would forks like the set below just bolt on without any mods to an E- series? I can use my front wheel, caliper, axle and odometer drive with these?
http://www.ebay.com/itm/Front-Forks-Tri ... a3&vxp=mtr
Has thanked: 153 times
Been thanked: 38 times
Re: Question on KLX fork swap
The steering stop is damaged.
What year E series do you have????????? If it is 1993 / 1994, I think the front wheel and brakes MAY fit. If it is 1989 - 1992, then no.
Dekon
Post by Dekon »
It's an '89, good pickup on the broken steering stop.
diymirage
Post by diymirage »
I don't know about stock tank sizes but I seem to remember that on any KDX with USD forks swapped in the steering stops need to be reworked anyway
I don't think the 1989 - 1992 wheel will work. I know for sure the caliper won't, as it mounts differently.
KDXohio
Post by KDXohio »
My E series didn't need any work done to the steering stops
KDXohio
Post by KDXohio »
These will bolt up and you'll need an axle, wheel, and caliper.
http://www.ebay.com/itm/Kawasaki-KX-125 ... f0&vxp=mtr
