where the heck do i put brake fluid?
vtwerm
It leaked out. I wanna put more in to find out where. Thanks for the help
jwhking1315
Re: where the heck do i put brake fluid?
Front or rear brake?
Front: next to the brake lever is the reservoir. The cap on it has 2 Phillips head screws in it. remove & fill.
Rear: same deal as front, but is near brake pedal
- Postigo
I strongly recommend you to buy the service manual, is money well spend and will give you the right instructions to do the job right the first time. Believe me you will save a lot of money doing the things right the first time.
- Postigo
Other chance is to get the online owners manual in the kawasaki site.
- KDXohio
Owners manual will tell you all your routine maintenance too
Kroynon
