Rear wheel bearings
Posted: 06:04 pm Jun 25 2013
by southernend
Been slowly bringing the ol 87 back to full service.Damn didn't realize how long it takes to get comfortable riding after 15 years hiatus from motorized bikes. Anyway looks like I need front and rear wheel bearings(wanted to wait till winter but decided not very safe) so I figured no problem-ebay. Front no problem but the rear ones,nothing. After doing a quick search here I'm still not sure on the solution. Anybody have a simple answer on where to find them? Been on the computer looking so long I' getting cross eyed lol.Thanks for any help.
Re: Rear wheel bearings
Posted: 06:08 pm Jun 25 2013
by KDXohio
Heres a link to them at pivot works. Id search their p# on ebay before you spend the 60$ might find them cheaper
http://www.pivotworks.com/ProductInfo.aspx?item_id=4556
Posted: 06:11 pm Jun 25 2013
by KDXohio
Ok sorry I did not notice theyre no longer making them so heres some from amazon they still have the kit in stock
Posted: 06:56 pm Jun 25 2013
CBR bearings used to have a kit. Look for a post from around 2005 on details.
You may be able to cross reference them with the numbers on the side.
Posted: 08:23 pm Jun 25 2013
by bufftester
Front bearings are the same as the E and H series 200's and the 220R. (6202UC3) Also used on the Ninja 250 and a few other bikes. Same with the front oil seal (MH20354.5)
Rear Chainring side Oil seal - BJNC2 25425 (1 ea) is the same as the E/H series 200s and the 220R
Rear Chainring side bearing - 6004UC3 is the same as the KLR650 all years and the KLX110 all years
Rear Brake side Oil seal - BJN 30374 is the same as the Vulcan 900 Classic 2006-2013
rear Brake side Bearing - 6804LU/2A (2 ea) is an NTN bearing, new # is 6804LLU/2A, also the same as NSK 6804VV. Have seen them on ebay, but not cheap. You may check with a local bearing supply, it is a 20 mm x 32 mm x 7 mm Sealed Both Sides, Deep Groove Ball Bearing or if you prefer online
http://bearingsdirect.com/6804-2RS-Ball ... ealed.html
Rear wheel bearings
Posted: 03:40 pm Jun 26 2013
by southernend
Went with the pivot works ones on Amozon.Thanks.
Posted: 06:16 pm Jun 26 2013
by KDXohio
Glad to help!
