Rear wheel bearings
southernend
Rear wheel bearings
Post by southernend »
Been slowly bringing the ol 87 back to full service.Damn didn't realize how long it takes to get comfortable riding after 15 years hiatus from motorized bikes. Anyway looks like I need front and rear wheel bearings(wanted to wait till winter but decided not very safe) so I figured no problem-ebay. Front no problem but the rear ones,nothing. After doing a quick search here I'm still not sure on the solution. Anybody have a simple answer on where to find them? Been on the computer looking so long I' getting cross eyed lol.Thanks for any help.
KDXohio
Re: Rear wheel bearings
Post by KDXohio »
Heres a link to them at pivot works. Id search their p# on ebay before you spend the 60$ might find them cheaper
http://www.pivotworks.com/ProductInfo.aspx?item_id=4556
KDXohio
Post by KDXohio »
Ok sorry I did not notice theyre no longer making them so heres some from amazon they still have the kit in stock
Has thanked: 116 times
Been thanked: 31 times
CBR bearings used to have a kit. Look for a post from around 2005 on details.
You may be able to cross reference them with the numbers on the side.
Front bearings are the same as the E and H series 200's and the 220R. (6202UC3) Also used on the Ninja 250 and a few other bikes. Same with the front oil seal (MH20354.5)
Rear Chainring side Oil seal - BJNC2 25425 (1 ea) is the same as the E/H series 200s and the 220R
Rear Chainring side bearing - 6004UC3 is the same as the KLR650 all years and the KLX110 all years
Rear Brake side Oil seal - BJN 30374 is the same as the Vulcan 900 Classic 2006-2013
rear Brake side Bearing - 6804LU/2A (2 ea) is an NTN bearing, new # is 6804LLU/2A, also the same as NSK 6804VV. Have seen them on ebay, but not cheap. You may check with a local bearing supply, it is a 20 mm x 32 mm x 7 mm Sealed Both Sides, Deep Groove Ball Bearing or if you prefer online http://bearingsdirect.com/6804-2RS-Ball ... ealed.html
southernend
Rear wheel bearings
Went with the pivot works ones on Amozon.Thanks.
KDXohio
Post by KDXohio »
Glad to help!
