New bike, having ish
ChrisZx7
Post by ChrisZx7 »
Quick rundown on bike
99 KDX200
Ran awesome when guy brought it over, traded my blaster for it. Orderd a new filter, and changed fluids. After all this, bike ran like crap at WOT. All bike has is a Pro circuit bike and stock silencer.
Jets that were in bike were 45/168. Did some research and found stock is 45/155. DId not work with 168, started at 155 and went up, no good.
I noticed a ticking noise at idle stator side, goes away when engine revs are raised. Took flywheel off, cleaned some surface rust, looked at stator. Im guessing its crank bearing?
Sprayed some carb cleaner around mating surfaces to maybe find an airleak. When i hit back of jug under reed it died. Guessing got a leak huh? Could this be reason for no WOT?
Forgot to mention i cleaned carb 2x throughouly.
diymirage
Re: New bike, having ish
Post by diymirage »
a ticking noise you say?
mhhh
sounds like you just been introduced to what is called a KIPS rattle
perfectly normal
ChrisZx7
Post by ChrisZx7 »
Just read about that 2 secs ago, well thats a breath of fresh air.
diymirage
Post by diymirage »
best way to be sure that is what you are hearing is to shift the bike in neutral and engage and disengage the clutch
it should make a slight change in the noise it makes
not sure why it does it, probably to let others know not to mess with you, like the brightly coloured poisenous critters :boogie:
ChrisZx7
Post by ChrisZx7 »
Ill try that tomorrow, thanks.
I would address the possible air leak before you go too far. That may be why the main was so big.
Welcome to the site :partyman:
ChrisZx7
Post by ChrisZx7 »
Thanks again for help. Since i posted this, bike has sat on stand. Haven't had motivation to work on it, that and im debating selling. Dunno what ill do yet, still deciding.
fuzzy
Post by fuzzy »
Yes. Change the reed cage gasket. No engines like an air leak, but especially true of 2-cycles.
