Spanner wrench for rear shock
Tyl3r
Post by Tyl3r »
What spanner wrench are you guys using to adjust your stock rear H-series shock? I was using the screw driver and hammer method to adjust, but am getting tired of marking up the adjuster and lock nut and would like a spanner wrench for it.
I saw this one on rocky mountain:
http://www.rockymountainatvmc.com/p/44/ ... ner-Wrench
The reviews seem like it works for some and not for others. I wanted to make sure the one I order will work. Anyone using this one?
Thanks!
Has thanked: 160 times
Been thanked: 40 times
Re: Spanner wrench for rear shock
The problem is having room to use it. Get a brass drift.
I have the Kawasaki factory tools, and there is no way to get them into the frame/shock area. They are just good for use when the shock is off the bike.
If a brass drift is too hard to come by you can try a hard wood dowel from the hardware store. It will be expendable but won't hurt the nut. I have some spanner wrenches and they can't get into the shock area enough to do anything but piss you off.
KarlP
Post by KarlP »
Usually you can loosen the top locking one and spin the spring to turn the lower one. You have to get the weight off the rear wheel and spray just a touch of lube on the threads.
