kick starting a bike
ArkAngel
Post by ArkAngel »
Hi guys,
i just want to know if anyone could give me some more advice.
The problem i have is that i can kickstart my bike and it will start after the 4 or 5 kick.
but after i stop the bike and try start it again i really struggle.
i have cleaned the spark plug but still the same.
does someone have something idea of something i can try?
i would really love it if i could kick start it every time, less then 5 kicks? hahaha
thanks
sent from my ipad
KDX 200
KDX 250
A clean and well adjusted carb will go a long way when it comes to starting.
Re: kick starting a bike
Yeah, good carb cleaning/adjustment, clean filter, tight boot connections. You want to make sure your intake system is good. My bike starts 2nd kick even after sitting all winter.
diymirage
Post by diymirage »
Your bike has NO buisness sitting all winter...why...i rode your old plastic through 2 feet of snow yesterday just to keep the juices flowing ;)
GKBO
Post by GKBO »
IIRC Ark Angle is in South Africa,he's bought a bike that's sat a while.
MotocrossMatt
Post by MotocrossMatt »
Ill just take a guess but hows the compression. Maybe you need a new top end or crank seals. Correct me if im wrong. Im also from S.A :grin:
Go buy a 2stroke!
MotocrossMatt wrote:Ill just take a guess but hows the compression. Maybe you need a new top end or crank seals. Correct me if im wrong. Im also from S.A :grin:
Also good advise.
cragwl
Post by cragwl »
[quote="diymirage"]Your bike has NO buisness sitting all winter...why...i rode your old plastic through 2 feet of snow yesterday just to keep the juices flowing ;)
Up and over here in the Pacific NW we have pond monsters and snow yetti's. They come out of there dens in late October and sometimes don't return to there grotto's until July 5th. They knock you off your bike and pee on your bearings rendering them use less. Local riding spots like "Tahuya" require dual snorkeling mods. One for the bike and one for "not drown'n". Many 50's and KLX 110's are found in the spring, sprouting up like tulips in a single track garden.
The snow yetti pushes over trees in the high country trying to kill you with exhaustion from heaving your bike up and over there block aids. I have "heard" that if you forgo yetti's warnings he will drain your tank of gas forcing you to hike your frozen bikeless arse out, spend a crappy night frozen in your truck waiting for daylight so you can hike back with 2 gallons of gas and heave your bike back over the dozens of huge trees cross crossing the trail so you can go home. I hate that Yetti!
In dog beers, I've only had one.
cragwl
Post by cragwl »
Had same issue, hard to start. I pulled the flywheel cover and oil and gas poured out. Cleaned with electrical parts cleaner and reinstalled cover. She started first kick. Time for a bottom end rebuild for me.
LOL...That's why I try to get over the other side of the mountains in the winter, but that's when the burrowing tumbleweeds come out, dig big holes, then jump in them to make it look like solid ground!
Compression check would be good to do, as well as checking the CDI/Magneto...oh and something dumb like spark plug gap can bite you as well :doh:
ArkAngel
Post by ArkAngel »
Hey all,
Well what i ended up doing is giving the carb a very good clean and it kicked first time.. So happy..
The Funny thing is i never cleaned the carb before, didnt think it got that dirty inside... i was so wrong... lol :shock:
KDX 200
KDX 250
Glad you got it sorted...you'd be surprised at the amount of crud that gets past the air filter, makes checking toe boot and clamps all the more important, especially if you ride anywhere really dusty.
GKBO
Post by GKBO »
ArkAngel wrote:Hey all,
LOL the first thing you get when you join GS Resoures with this kind of problem is "clean your carbs and not half way either".Think about a rack of 4 VM26 carbs off a 78 GS1000 varnished to immobility,yeah carbs get dirty and worse.
