KDX220 kick starter loose
potosi joe
My kick stater is loose, and swings out to far letting your foot slip off when wet. Low on funds and don't want to built a full hybrid set up. Will the kick stater from a 2000 KX250 bolt in and work using the whole assembly? Thanks Joe
- Has thanked: 9 times
- Been thanked: 17 times
Re: KDX220 kick starter loose
I think so, Joe. I'm using a 99 kx250 boss with a kx125 lever. The whole 250 unit should fit.
- doctord23
Yes. A kx250 kickstart lever from 02 and prior works great.
That's what I run.
You do still need to use a washer behind it so that the nut tightens.
I believe it is a 5/8".
That's what I run.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
cornishwrecker220
kx boss fitted to the kx 125 `shorty` kicker is one of the best/useful mods i`ve done to my 220.
potosi joe
Thanks guys. It looks like I will start with the 250 starter and go from there. Thanks Joe
rsr02
How does the full KX250 system fit? Any problems with the lever hitting the tank? Is it shorter then the kdx one?
1997 220, KLX forks-pipe-reeds-trials tire
