1998 KDX 220 Clutch Bolts help please
clescault
How tight should I put the the clutch spring bolts on, and the main bolt in the very middle, not sure exactly what its called.
- Has thanked: 15 times
- Been thanked: 27 times
Re: 1998 KDX 220 Clutch Bolts help please
Hub nut - 65 ft-lb
Spring bolts - 78 in-lb
I highly recommend a service manual. The cyclepedia manual linked on our home page is quite good. If you just do a 1 year sub, just make sure you've printed the whole thing out before your year is up.
