Spooge--exhaust port
terminatr
I find a lot of spooge dripping out of the pipe at the exhaust port. I replaced that copper ring gasket not too long ago; so it should be good. So why is it all of a sudden starting to drip spooge?
2001 KDX220
- scheckaet
check your reeds for leaks, cracks...
air filter clean?
using different oil? different gas brand?
jetting right on? http://www.kdxrider.net/forums/viewtopi ... 105&t=1156
it can take awhile for spooge to accumulate in the muffler and finally drip...
air filter clean?
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
ukkdx200
I had this problem did you buy a genuine kawasaki copper gasket? I first got a cheap one from ebay and it didnt work, got one from kawasaki and it fixed it for a few weeks untill I left my exhaust bung in the exhaust after washing started up and it went again! doh!
terminatr
Re: Spooge--exhaust port
Oh I see. Didn't even know there are o-rings there. I guess they're shot.Dekon wrote:Are the two o rings on the pipe good?
2001 KDX220
Dekon
I have an E and it has two o-rings where it inserts into the cylinder.terminatr wrote:Two? I only see one.Dekon wrote:Are the two o rings on the pipe good?
terminatr
Yes. I see now there are two o-rings on the pipe and also a copper gasket at the end of the pipe.
2001 KDX220
KarlP
It is usually a good idea to put a layer of hi-temp RTV over those o-rings and let it set up over night after installation.
terminatr
- scheckaet
yup
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
terminatr
Darn. Those OEM o-rings are $10 a piece. The part number shows it is 39mm.
Is OEM the only option?
2001 KDX220
Dekon
FMF makes them. Check here: http://www.rockymountainatvmc.com/p/43/ ... st+o+rings
Not sure if the KDX is listed, maybe you can cross reference from a KX.
- rbates9
- Been thanked: 2 times
Do your springs feel like they still have enough tension? Might be worth getting a new set if they are feeling weak.
terminatr
They look very rusty, but there's still a lot of tension. Very tough to install the springs, using a vice grip.
2001 KDX220
terminatr
Maybe the springs are bad. I went ahead and got new aftermarket springs and put 'em on. They are crazy strong. They were much, much more difficult to put on than the rusty stock ones. I suspect this is the main problem.
2001 KDX220
ukkdx200
get yourself a spring puller will make things much easier
http://uk.images.search.yahoo.com/image ... d58iqJ3tiP
terminatr
I replaced the spring. Now, no more leak.
I didn't replace the seals because I'm too cheap.
2001 KDX220
- rbates9
Did you replace the "spring" or the "springs"? There should be two of them.terminatr wrote:I replaced the spring. Now, no more leak.
terminatr
Yeah, got 'em both two pieces of spring replaced. The new one is really tough to get on. It's aftermarket
and shaped different. First time, my vise grip slipped off the spring, and I went flying backward. It took alot of he-man muscle to get it on.
2001 KDX220
- GreatBritishRob
