Spark plug fouling
Redraider172
Spark plug fouling
Dear KDXrider.net users,
I have had my '03 KDX 200 for about 2 monthes now and i've had a problem occur twice. I'll be riding around my yard and the bike will make a sound like it just drowned itself and it then shuts off. I kick it many times and it won't start. I determined the problem to be a spark plug fouling so i cleaned it and it ran fine. The problem happened again yesterday and this time a good spark plug cleaning did not solve the problem. I run a 40:1 Fuel:oil ratio and that seems to be a bit thick based off the density of the exhaust but i am nervous about changing it because thats what the service manual reccomends. I've read several recomendations online about similar problems and some solutions were to adjust the jet and change my ratio. I was considering these options but i would greatly appreciate some more recomendations or solutions.
Nate
Nate
- scheckaet
Spark plug fouling
http://www.kdxrider.net/forums/viewtopi ... 57#p117919
http://www.kdxrider.net/forums/viewtopi ... 105&t=1156
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- rbates9
- Been thanked: 2 times
Spark plug fouling
Like he said.
Also, when you foul a plug put in a new plug. Cleaning plugs is to get back home. Plugs are cheap and dirt bikes don't push easy.
Roadhazardguy
Re: Spark plug fouling
If it still does it after you jet it down some it could be your right crank seal leaking transmission fluid into the crank case. Have you noticed your oil level going down?
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
KarlP
Some jetting work is probably going to have to be done. It is not hard to do.
I've never had very good luck cleaning plugs. Once they foul they are pretty much done for.
I think 40:1 is fine. Just poking around in the yard with possibly rich jetting is bound to foul a plug.
Fletch
could be time for a top end refresh too. That did it for me, and I haven't changed a plug since (about 40-50hrs ago)
Fletch
- scheckaet
Spark plug fouling
or mixing different brand
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
teamgreen
- fuzzy
and your air filter
Redraider172
Thank you all for your responses. I use Yamalube oil for the mixture and thats legit from what i've read. Am i wrong? I just put in a new air filter before the problem happened the 2nd time and i checked it and it was fine. My oil level has been constant and i haven't noticed it going down. I don't know how to adjust the jets. Anyone got an article or youtube video link? Thank you all again for your help.
- rbates9
Spark plug fouling
As far as which jets to use you will need to find out for your self by going thru this http://www.kdxrider.net/forums/viewtopi ... 105&t=1156 then you should be close.
If you are looking for a how to on getting at the jets then we can probably help you out there also.
Redraider172
- rbates9
What did you do to fix it?Redraider172 wrote:Thanks a ton everyone, got it workin again :)
- fuzzy
If you just put a plug in it will foul again. You've covered all the bases but jetting.
Redraider172
Spark plug fouling
I put a new spark plug in and changed my mixture to 50:1 to avoid the problem again. If it happens again i'll adjust the jets. I realized i'd been cruising too much around the yard (despite its a 3x4 acre yard) I've noticed a larger than normal amount of oil coming out of the exhaust pipe. I feel like i need to ride it harder and keep in a lower gear for cruising.
- rbates9
Spark plug fouling
Adjusting the oil mix to the bike isn't a great idea. It would be well worth your time to go thru the jetting and get that right. You will be surprised at the difference a well jetted carb will have on the overall performance of the bike.
- scheckaet
Spark plug fouling
going from 1:40 to 1:50 ratio you've only done 1 thing and that is RICHEN your mixture.
you will foul plugs again.
i think i'm done trying to help newb crying for help that won't listen to advice
i get the feeling this will fall into death hears...some people refuse to listen no matter whatrbates9 wrote:Adjusting the oil mix to the bike isn't a great idea. It would be well worth your time to go thru the jetting and get that right. You will be surprised at the difference a well jetted carb will have on the overall performance of the bike.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Redraider172
okay' i'll change the ratio back and adjust the jets. I apologize for my ignorance. I have not been working on dirtbikes for very long so i am a little nervous about making mechanical adjustments as i have never really done it before.
