kdxtreme's hybrid build
So I have the 2005 kx starter kit on the way. Also on the way 2009 kxf dlc coated complete forks, subframe 05 kx, radiators 05 kx, new warp 9 wheelset green hubs and black rims, all new plastic, have protapers and cycra handgaurds already, need to sell the TM 450 then I can pick up a KDX200 and the rest of the parts.
Did I say riding?
- Tedh98
Re: kdxtreme's hybrid build
Sounds like you are off to a good start.
Are the forks from a 250 or 450?
Got the forks in hand now they are a straight bolt on.
will have pictures when the chassis is a roller.
Did I say riding?
Bar mounts came in air box is here new renthall twinwalls, plastic is here, front brake on the way, also seat on the way, starting to look like a bike
Did I say riding?
They are off of a 250Tedh98 wrote:Sounds like you are off to a good start.
Did I say riding?
got gold on gold excel/talons on the way for good deal
then its a roller
Did I say riding?
Renthall twin walls, tm designworks chain guide,polisport mmx light, new cycra hand gaurds been changing it up a little as I go
waiting on a call back on a 2001 200
Did I say riding?
scored a 99 220 with fredette kicker, ims shifter, rb mods and new front tire for cheap.
now its time
Did I say riding?
I'll probably get booted off the forum for saying this, but I want to check out that TM 450!
David Eckel
The TM is a sweet bike all hand made pics are on Tasky's Metric Cycle website under used bikes low hour bike still has stock plastic and alllof the switch gear is there for turn signals and horn still works.
Did I say riding?
- marrk_us
Ran into the same thing with the CR build, found a H series kicker, shortened it by 3/4" and fits nicely (someone on the site would probably make you a swap). The shorty kicker was too upright and hit the frame. Glad you got the engine fitted, with the CR an extra set of hands made it a lot easier. Looking forward to some picskdxtreme wrote:Motor in fredette kicker don't fit
I'm going to try clocking it forward first if no go then I'll be looking to trade.
Did I say riding?
Its close now gonna grind it and fill with weld to build it back up on the inside. Working on the airbox also almost done with that. Pipe fits like factory just need to relocate the lower mount on the frame.kdxtreme wrote:I'm going to try clocking it forward first if no go then I'll be looking to trade.
Did I say riding?
- marrk_us
