'89 Jetting issues, want to know if I'm doing this right
KDXrider1989
Post by KDXrider1989 »
I messed with my carb a while back when I got my FMF pipe and boyesen reeds, and it seems like my bike is running rich since then, or richer. It smokes a bit and just feels a little down on power, so I opened up the carb yesterday. Still found the 45 pilot and 155 main (I live near sea level and temps in the 90's), but I noticed with the carb upside down it measured about 14.5mm from the float bowl mating surface to the top of the float. It states in my manuel that it's supposed to measure 16mm, so I corrected it and ran the bike and now it feels like it's running lean, or is it that the bike is actually running better and I'm not used to the power? The exhaust smells a little different too. Followed the jetting guide on here and I'm at 1 turn out on the air screw, when I used to be about 2. I guess my real question here is: could a 2mm difference in float adjustment screw up the motor?
Has thanked: 160 times
Been thanked: 40 times
I am no jetting master, but if it says 16mm, then it HAS to be 16mm. Any tuning should be done after that is done. I am just thinking, any tuing you did before was somewhat compensating for the level being off (or if it went off, then it threw it all off).
Has thanked: 30 times
Been thanked: 47 times
I agree with Jason. You got to have your float level set right first and then you can start messing with your jetting. Follow the jetting guide to get it spot on.
KDXrider1989
Agreed, that was with the tang not bent at all, had to bend it to get to the factory 16mm level which I thought was kinda weird, unless the floats were bent :hmm: I measured from both sides of the float and they were both at 16mm. This may be a dumb question to ask, but in the case of bent floats, would 16mm from the flat surface to the top still be OK since its 16mm?
MikeyMike
Re: '89 Jetting issues, want to know if I'm doing this right
Post by MikeyMike »
Where'd you get the headlight?
KDXrider1989
MikeyMike wrote:Where'd you get the headlight?
It's a UFO Twins, got it used for a very good deal on ebay
