Blowing oil all over?
I like toys
Post by I like toys »
Made my KDX street legal in VT and enjoy going to bike night on it more than i can describe.
Mix is right, or fairly close, always had 4 strokes before, but... oil every where even on jacket. beautiful black stuff dripping out of pipe.
does not seem to be loading plug, any ideas?
Frysk
Post by Frysk »
What kind of oil do you use to mix ?
sped66
Post by sped66 »
Excessive spooge is generally due to a rich condition. Check the jetting guide on this forum.
In the stable: '00 KDX220R, '02 XR250R
Gone but not forgotten: '80 XR80, '87 XR200R, '94 KDX250, '01 YZ426F, '86 XR220R
Frysk
Post by Frysk »
not necesarily (uh how do I spell this?) true, my bike is jetted a bit rich, no spooge at all.
The right two stroke oil is the answer in my opinion.
Putoline MX5/MX7
Castrol TTS/TTX
these are the 2 I mostly use.
Both are full syntetic oils and are designed to produce no/minimal carbon deposits, burns fully up.
Spooge is unburned oil.
david
Country: UNITED STATES
Post by david »
What ratio Frysk? I mix the cheap SuperTech stuff from Walmart at 40:1 and get the same excess spooge on my back and fender at high speed. I know the oil is my problem.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
spooge will be affected by the type of oil you run, temperature, humidity, the ratio you use and obviously: the jetting.
It is not just un burnt oil, it is un burnt fuel mix due to too rich of a condition.
you will get some spooge no matter what unless you could be spot on all the time under all temp, humidity and your altitude never changed... close to impossible imho.
if you are getting a lot of spooge all the time, one of your circuit is too rich (from what you describe, i'd guess the main is too fat).
I'd follow the jetting guide again and do a plug test.
My .02
I noticed that when I started using marine StaBil in every thank my spooge level decreased with no jetting changes. I attribute it to the anti ethanol properties. But yes, jetting and premix oil is the main cause of spooge.
fuzzy
Post by fuzzy »
I would stop using that walmart oil and go to a full synthetic. Also, even if you 'cured' your spooge problem you'll never know without repacking your silencer.
david
Post by david »
Yeah, I will. I hate having oil splatterd all over the back of my shirts. Going to pick up some 'smokeless', full synthetic this weekend. Then I will work on repacking the 22 year old silencer. I'm sure it is going to be real pretty in there.
'81 KDX 175
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
Frysk
Post by Frysk »
david wrote:Yeah, I will. I hate having oil splatterd all over the back of my shirts. Going to pick up some 'smokeless', full synthetic this weekend. Then I will work on repacking the 22 year old silencer. I'm sure it is going to be real pretty in there.
be sure to get oil from a good brand..
And don't get Denicol oil, thats mineral oil and creates even more spooge.
kyledsmith87
Post by kyledsmith87 »
I personally think a little bit of spooge is necessary, remember you want your power valve to be at least a little bit wet!
Frysk
Post by Frysk »
kyledsmith87 wrote:I personally think a little bit of spooge is necessary, remember you want your power valve to be at least a little bit wet!
yet that doesn't mean that it should come out of the back end of your bike.
kyledsmith87
Depends, in the 80's it did. Now everybody wants to run 9999:1 fully synthetic ratios. There is a big difference between the odd drop here and there and pools of it though :?
Frysk
Post by Frysk »
kyledsmith87 wrote:Depends, in the 80's it did. Now everybody wants to run 9999:1 fully synthetic ratios. There is a big difference between the odd drop here and there and pools of it though :?
The reason for that is that oil and gasoline nowadays are of higher quality (especialy the oil)
I run 1:40 full syntetic and not a drop of spooge at the back of my bike, but when I pulled my cilinder apart the kips was greasy.
