newer carb for 1984 KDX 200?
taco jeff
Post by taco jeff »
Can anyone give me some advice about upgrading the carb on my 1984 KDX 200? The Mikuni on it should be a 34ss(?) . The carb I have is a round slide that measures 38mm on the motor side I.D. and has an"ovalized" cross section top to bottom. It has no ID other than Mikuni on it. I had a 1995 KDX with the RB carb mods and loved it. Would a 200 or 220 carb work with my non-KIPS motor? My carb is 45mm O.D. motor side,57mm O.D. air box side and 97mm long between the ends. Tight trails and vintage mx is what I do with the bike. Thanks in advance...
Has thanked: 195 times
Been thanked: 52 times
Look on the Keihin site for dimensions of a PWK35. If your carb has the same dimensions as my 1987 VM34SS (1987 KDX200), then both round parts are different dimensions, plus the width between the two boots.
Been thanked: 2 times
