Before you swap in a bulb of that magnitude, make sure your stator can support it. My rewound stator tested to 103W. The thread on that can be found here: http://www.thumperta...r-rewind-how-to
I bought a replica KLX450R headlight from eBay. I really liked the look of it, and at $40 it's about 1/4 the cost of the actual Kawasaki unit, and it has rubber mounting straps which are much more forgiving than the Kawasaki bolt on type. It includes a dual filament 35W bulb (useless) and a 194 peanut bulb "parking light" (also useless.) I decided to get green, and paint the "number plate" area rather than have an all white housing.
I used to use white vinyl to make my number plates, but I switched to paint awhile back when my pressure washer kept stripping the decals right off. Here you can see the headlight masked, sanded, and ready for adhesion promotor and plastic paint:
Painted light:
Next up was to ditch the factory 35W useless bulb and gut the housing.
I cut down an H7 to H4 bulb adapter (reason for this explained later) and cut down the stock bulb socket.
Next, you'll need to use an OLD soldering iron, and "plastic weld" the two pieces together. Get the iron hot, and make sure to get good penetration for a strong bond. It may not look pretty, but you can see the good "mix" of plastics which ensures a strong bond:
After joining the pieces strongly on both sides, we now have a socket that will fit the housing, and hold an H7 bulb:
Installed:
