Side Stand Bracket Question
Fatherof2
Post by Fatherof2 »
Hi Gang,
I bent my kickstand bracket so that when the stand is down, it goes STRAIGHT down. There is no lean to the bike.
How can I fix this? Take it off, and bring it to a machine shop to heat it and bend it? Thoughts?
They are 50 bucks on Babbits including shipping! Ouch! I would rather try to fix this one.
Thanks for any help.
David
For God and Country......Geronimo, Geronimo, Geronimo!!
turtle
Post by turtle »
I'd probably remove it from the bike, then heat and beat it myself. I know this is a beefy part but I bet you can fix it.
Bill
Central IL
2004 KDX220R
2011 Triumph Tiger 1050 SE
Been thanked: 2 times
I have bent mine a little, not straight but some and was able to lay the bike over and swing the stand down then just pulled on it until it looked right. Might be worth a try before you remove it. If you think its not going to go than take it off and heat it up some.
Fatherof2
Post by Fatherof2 »
Thanks guys,
I will give the blow torch a shot first.
I cant believe how much I bent the bracket.
Thanks again,
D.
david
Country: UNITED STATES
Post by david »
Put it in a vise and whack it with a hammer.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
Yes, cold bending would be better than heating it if it will go that way. Heat alters metal, usually not for the better. :wink:
