turn signals (again)
diymirage
Post by diymirage »
hey guys, i know this has been beaten to death but i got ask
how do i make turn signals flash on my KDX ?
i pieced together a set up of LED turn signals and a nice switch
everything works but i can not get them to flash (im guessing non of the flashers are compatible with the AC system)
i tried the regular flashers aswell as the ones intended for LED lights but still no dice
im running a stock stator so installed a rectifier will not do (tried it, dropped the output down and dims the lights way too much)
any suggestions ?
Has thanked: 14 times
Been thanked: 22 times
Run a small rechargeable battery pack.
KDX200-E2
Post by KDX200-E2 »
SS109 wrote:Run a small rechargeable battery pack.
This would be likely to be the easiest solution. Run a complete isolated
lighting system. Your range will be limited if you run the headlight. Running
just the brake and turn lights, a 4-5Ah battery should last all day. A 35W
headlight will suck that dry pretty quick.
I did the Rectifier/Regulator with a battery conversion on my KDX240SM with
great results. Make sure you isolate the rectifier from the frame. All of
the lighting system needs to be free of any frame grounds. I grounded
all the lighting to the negative side of the battery. Nothing touches the
frame, except the ignition system, which I kept stock.
I should do a write up on my project, but, I am pretty lazy and may not
get around to it any time soon. You may find some info in my past posts
if you search on "KDX240SM" *HINT* I used a complete wiring harness
I got from a Canadian model GasGas EC250. It had all the connectors
for the brakes, turn lights, horn and running lights already done. Made
the job way easy....sort of.
Jeff
diymirage
Post by diymirage »
thanks Jeff
i use my bike mainly as a daily commuter and i am not looking forward to pulling the seat of to get to a battery every night so i can ride the next day
i tried the rectifier but it just drops down the output way too far
(as it is hitting the brakes will kill the headlight)
im afraid the best option is a stator rewind and then ad a rectifier but im just not up to that right now
Brian
Post by Brian »
you can run wires from your battery to a remote location to make the connection to the battery charger easier to get to.
diymirage
Post by diymirage »
wow, that is briliant
i just might do that :)
KDX200-E2
Post by KDX200-E2 »
diymirage wrote:wow, that is briliant
Search "battery tender" they have a pigtail that mounts to the battery
and has a quick connector to the charger,
Jeff
