Hey guys,
I was riding my 95' KDX 200 the other week and towards the end of riding I tried to shift my bike into first..but it just wouldn't shift. It would only stay in neutral. When I tried to push the shift lever down it would hit the skid plate.
I figured my shift lever was broke but I took it off and the threading is fine and there doesn't seem to be any issues. I've tried adjusting the shift lever as well thinking it came undone but it seems to be in the correct position..
I am thinking it is internal and most likely the gear shift shaft assembly that is broken..but not really sure.
Any Ideas?
Can't get bike to shift into first..?
Ravensdale-Rider
Ravensdale-Rider
Ron-e
MadMax
I'm guessing something has gone wrong with your shift drum assembly. I had a 125 KTM that did the same sort of thing. One of the little spring loaded flaps that engage the drum had gotten stuck closed. Probably clutch plate material or some such got into and stuck the mechanism. 20 minute fix.
MadMax
Jedi Master Team 5150
kawabunga
Ravensdale-Rider
