Rebuild gasket set
kawabunga
Rebuild gasket set
Post by kawabunga »
I,m looking to buy a complete engine rebuild gasket set. Before I go and buy the cheapest set on on E-Bay, I would welcome any input on quality and /or things to look out for.
Also am also planning to send my head into RB, and need to send Ron a solder sample per his site instructions. I need to know if I compress the head gasket for this test if I can reuse it. Or do I need to buy an extra?
reviving old war-horse.
Deseret Rider
Post by Deseret Rider »
Consider these guys for the gasket set---they are pretty good vendors.
http://www.rockymountainatvmc.com/
The Duck of Deseret (Deseret was Utah's first name)
Has thanked: 30 times
Been thanked: 46 times
I'm a firm believer in factory gaskets. If you choose to go with one of the kits on the market I suggest, at minimum, getting factory head and base gaskets.
never had an issue with the 3 topend gasket kit I used...
what don't u like about them?
It is mainly piece of mind but it also the consistent quality that is important to me. With aftermarket you never know if the basket gasket is the proper density or thickness as the factory piece. Same kind of applies to the head gasket as well in the quality of the metal. I have an aftermarket gasket set for the 200 but I have all factory seals and factory head and base gaskets.
OLHILLBILLY
Re: Rebuild gasket set
Post by OLHILLBILLY »
kawabunga wrote:Also am also planning to send my head into RB, and need to send Ron a solder sample per his site instructions. I need to know if I compress the head gasket for this test if I can reuse it. Or do I need to buy an extra?
You don't have to send the solder sample pieces to Ron for a KDX head. And no, once the gasket has been compressed you can't reuse it.
2004 KDX 200.. Coupla mods
2009 KX250F.. Track Star
Mr. Wibbens
Post by Mr. Wibbens »
I call bullshit
factoryX
Post by factoryX »
:roll:
Been thanked: 17 times
Mr. Wibbens wrote:I call bullshit
If anyones an expert on reusing old parts again it's you, right?
some reuse the old head gasket after cleaning them and coating them with copper spray I believe. Never heard of anyone having issue with that. would i do it myself? nope cuz I like the piece of mind when I use a new kit.
paulkdx220
Post by paulkdx220 »
as long as the head gasket is not a crush type, you can anneal it with a propane torch and re-use. i don't know what the kdx uses as i've never had it apaty. i do that with my old kawi triple. a light dusting of copper spray is good on new and old gaskets.
Mr. Wibbens
Slick_Nick wrote:>|<>QBB<
Did you just say that? :rolleyes:
gsa102
Post by gsa102 »
I have re-used head and base gaskets before but that doesn't mean you should. It would be relatively easy to replace the head gasket if it leaked. For peace of mind I would buy new.
96 KDX 200, 09 YZ 250
KarlP
Post by KarlP »
Cometic makes a good gasket kit. At least, I've never had any problems.
I'd re-use a head gasket if I HAD to. I can't see trying to use re-use a base gasket. They usually fall apart.
Ron does not need the solder bit for the KDX. Ask him.
kawabunga
Post by kawabunga »
Thanks for the replies.
It sounds like a head check is not required.
Cometic was the good s**t for turbo DSM's.
My past automotive work saw a huge difference in quality.
Hate working with this low budget, unfortunately the toy gets paid last.
cornishwrecker220
Post by cornishwrecker220 »
pattern gasket kits are fine but i would use a genuine kawasaki item for the head as they have (they did on my 220) a tacky coating which super seals the head..i also use a light coating of grease on base gaskets & inlet/reed gaskets, for the exhaust side a small amount of hi temp silicone (the type used on boiler joints) works good, seals nice is flexible & prevents the exhaust from blowing & dripping sticky 2 stoke oil around the pipe & frame! :wink:
