dropped circlip in bottom end
bud burner
I am rebuilding the top end on my 1990 kdx 200 and when i was putting the piston in I dropped the circlip in the bottom end. I could not get it out, and I do not want to open the bottom end. Will it be ok if I leave it in there. It is real thin and i think it will get ground up without causing any damage.
- wbdisco
- diymirage
i'd put it all on black 26
(point being, if you're a gambling man, go for it.)
if it were me i would try to turn the engine upside down and shake it, or try to flush it out somehow
i would not be comfortable with ANYTHING in there
- Mr. Wibbens
unless it gets sucked up and stuck between the piston and cylinder LOL
bud burner
- scheckaet
yeah go ahead and throw in a handful of sand too, that's small enough right, shouldn't hurt anything, SHOULD IT?
sorry i could not resist a bit of sarcasm.
you NEED to take it out. Try to flip the bike upside down and flush it with some gas or oil, i can't recall which one. Hopefully someone will chime in and give more advice. (after they give u crap though
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Mr. Wibbens
just think what those little bits could do if they made it through the bearings and into the seals
- diymirage
ez
You need to find it!!!! my sons kx100 had one come out scarred the cylinder wall enough to lose compression. I didn't find all of it..well.. a couple hours on a new topend and it locked up..part of the old clip got back up. I learned the hard way
jumping is no problem however landing is another story
- diymirage
the guy with the rear view mirror is of course depicting the engine of the KDX
the guy who says "i was just buzzed" is our OP who said "It is real thin and i think it will get ground up without causing any damage"
and the paramedics is all of us, who are trying to point out that even though it is a small little doohickey it is still a foreign metal object that found its way into the engine
Deseret Rider
Wonder what would happen if he stuck a very thin and powerful earth magnet on the crank and just run it around 360 degrees?----think it would pick up the clip and bring it to you? Or would you now have a clip and a magnet stuck down there??? Is there enough room between the bottom of the crank and the case to pass the magnet? Iv'e got an assortment of those earth magnets---some are about as thin as a nickel and powerful enough to stick pretty hard to the crank.
I am not advocating that he try this just yet---just throwing it out as a possibility if all else fails. First thing I'd do is turn the bike upside down on a spread out sheet or blanket (so you can find the clip if it does come out) and blow compressed air up there hoping it would blow the clip free ---and if that didn't work I'd turn the old garden hose with a small nozzle and hose it down while spinning the crank----not the best idea for the lower crank bearing----but a whole lot of WD -40 followed by an oil bath afterwards. Trick is to know the clip came out and find it afterwards---which is the reason for the blanket
The Duck of Deseret (Deseret was Utah's first name)
- Mr. Wibbens
compressed air and a big fuggin speaker magnet
- fuzzy
bud burner
Green Hornet
antenna magnet wand. Fish around the case and you will find it. I did it once, and I did recover it. Be patient.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
