more watts
paulkdx220
more watts
Post by paulkdx220 »
are there any light bulbs available that are higher wattage than the stock 35w that will fit the stock light housing?
Has thanked: 34 times
Been thanked: 57 times
None that I have found. The H6M bulb is very limited in options. BTW, 30 watt is stock. A 35w is an upgrade.
diymirage
Post by diymirage »
from what i understand the stock coil wont power anything over 35W anyway
Has thanked: 15 times
Been thanked: 28 times
Correct. If you want to run higher wattage lights, you need a higher output lighting coil.
paulkdx220
i have a 65w coil
You'll have to go to the aftermarket for a more powerful headlight. I picked up a Polisport MMX. It comes standard with a 35w bulb but you can also get 45w and 60w bulbs for it.
