plug fouling :'(
stomlinson
plug fouling :'(
Post by stomlinson »
Whats up kdx army?? I have an e series kdx 91, rb carb mod, head mod, fatty pipe, boysen rad valve, uni filter. When I put all pieces together this year the bike ran first kick and pulled like crazy!! But after a few good rides everytime I start it up it fouls a plug. Now just today it fouled 2 plugs while riding. And I found my bottom end lacking the sharp snap it had. to me it makes no sence that this could be a jetting issue because of how good it ran on the first 3 or 4 rides. Any one ever had this problem before?? Thanks for the help
Mr. Wibbens
Post by Mr. Wibbens »
what plug?
Fletch
Post by Fletch »
Kips jammed? Compression?
Plus what wibbs said
Fletch
kdxmaniac
Post by kdxmaniac »
Mr. Wibbens wrote:what plug?
its the plug that goes in the bottom of the motor :roll: ..i think its called a "oil drain "plug" :hmm:
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
kdxmaniac wrote:>|<>QBB<
Uh, I think Wibby is referring to whether it is an NGK, Denso, etc, and the plug designation like BR9ES, or a BR8EG, etc. Which one it is does make a difference.
stomlinson
The plug I run is a br8es. On the weekend I lowered my pilot jet from a 40 to a 38 im going to see if that makes a difference, I also raised my needle clip up one notch
fuzzy
Post by fuzzy »
Clean air filter?
Mr. Wibbens
SS109 wrote:>|<>QBB<
I was just making sure he was not running a 9
stomlinson
Yes air filter is clean
Fletch
Post by Fletch »
Check your kips and compression!
Fletch
gregp
Post by gregp »
When my "H" series bike started fouling plugs, went crazy with everything I could think of - air filter, reeds, top end, jetting, etc.. It turned out to be the source coil was weak. I bought a replacement from Ricky Stator for $70 and my bike was transformed into a 1 kick starter, never fouling a plug - ever.
Check the resistance of your source coil. The reading should be something like 270-340 ohms. Mine read 150-ish. Look to the shop manual for the correct specs for your bike.
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
