all of the 95+ owners knows that no one make a clutch basket for us, and the stock cast one sucks.
wiseco has agreed to do a small run, if i can get 10 people together or more, they will do it. the price will be less than $200 for a new forged clutch basket. please go to TT and post if you are interested.
http://www.thumpertalk.com/forum/showth ... p?t=994373
thanks!
Wiseco Clutch baskets for 95+, group buy opportunity
hi_im_sean
hi_im_sean
- Been thanked: 19 times
dfeckel
You can make the 95 and up baskets work with the 89-94 bikes, but you need all the ancillary clutch parts, including plates, hub, pressure plate, springs, etc. You basically need the WHOLE clutch assembly. The only thing I'm not 100% sure on is whether the earlier cover is deep enough to fit over the later assembly.
David Eckel
- ss109
- Has thanked: 34 times
- Been thanked: 57 times
Sorry but it doesn't fit. The KDX200 and 220 are based off the KX125 engine where the KDX250 is based off the KX250 engine. The basket for the KX/KDX250 is quite a bit larger than the KDX200/220,spaun wrote:Does this also fit d class 91-94 Kdx 250s?
