Another kips question
xtrema2
Post by xtrema2 »
I have a 95 kdx 200. I took the slotted cover off to expose the kips shaft. It turns freely with a nut driver but when I start the bike it seems like the shaft rotates 1/4 turn when i rev the bike. I'm pretty sure it's opening all the way just not returning all the way. I dont know anything about these bikes, any help is greatly appreciated.
Been thanked: 19 times
If it's not returning all the way it's probably gummed up. Time for a top end.
xtrema2
Post by xtrema2 »
A top end rebuild or just tear down n clean up.
Coop
Post by Coop »
Well if you are going to tear it down to clean the powervalves, you might as well inspect the cylinder, inspect/measure the piston (replace if close to limits), replace the rings, wristpin bearing, circlips, gaskets, etc. You have to pull the cylinder to do the valves.
2003 KDX200
xtrema2
Post by xtrema2 »
thanks guys.
