Kips gov. bearing
Mr. Wibbens
Kips gov. bearing
Post by Mr. Wibbens »
Anyone ever get this fugger out easily?
Inner diameter is 8mm
Yup.
If you take a 1/4" bolt a few inches long and attach the threaded end to your slid hammer some how ( weld it to a nut or if you have an adapter to thread it into ) then grind down the hex head leaving a lip on about half of it until it will fit in the hole You will need to also relieve some of the bolt diameter to let the lip to clear the bearing. You can catch the edge of the bolt on the edge of the bearing and pop it out. Or you can buy the $200 kit that is made to do it, but the one that I had didn't have a puller tip that would fit so that may not work.
I don't have the "tool" that I made at my house but I can get it if you need a picture.
kdxmaniac
Post by kdxmaniac »
this is the kit ive got. works great, and comes with a 8mm.
http://www.mactools.com/SearchResults/t ... =mn08-0292
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
kdxmaniac
Post by kdxmaniac »
heres one thats alot cheaper, and really the same thing.
http://www.rockymountainatvmc.com/produ ... lyId=20342
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
Mr. Wibbens
Talking big $$ for a $2 bearing
Hopefully I can find someone with a puller
there's only about a mm or less of space behind the bearing
The inner bearing for the water pump shaft is 6mm, I'd like to get it too
spose you could tack weld something to the bearing and get it with a slide hammer. But I have neither a welder nor a slide hammer
Mr. Wibbens wrote:Talking big $$ for a $2 bearing
You can make a slide hammer out of just about any thing. Threaded rod and something heavy.
how about heating the case a bit a putting some dry ice on the bearing? might be enough to get it looser and remove it with a screwdriver or sumthin.
kdxmaniac
Post by kdxmaniac »
you can also use concrete ancors. get one the size you need, put the bolt in a body slide hammer, and there you go.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
Drill a hole from the out side of the case and drive it out with a punch! :lol: Then it will be easier next time also! :partyman: You could plug the hole with some JB weld or something. :rolleyes:
Mr. Wibbens
A friend already suggested that :wink:
Mr. Wibbens
Had an "Ohh duh!" moment
I was applying heat here
Instead of here
Heated the case around the bearing and shot it with some canned air and then slammed it down on a wooden bench, popped right out!
:supz:
Mr. Wibbens
Still making bad noises :sad:
Pull top end next
Mr. Wibbens
Replaced everything in bottom end last year except the rod bearings
Mr. Wibbens wrote: except the rod bearings
:roll:
Mr. Wibbens
Had no reason to, it checked out fine
Plus I had neither the time nor the money to do anything more
I had a day to get the bottom end done before a big ride/camp out
Mr. Wibbens wrote:Had no reason to, it checked out fine
Understood, been there.
Mr. Wibbens
Found it :twisted:
Has thanked: 9 times
Been thanked: 17 times
Dang. And those were new last year?? What bearing kit did you use?
TWMOODY
Re: Kips gov. bearing
Post by TWMOODY »
>|<>QBB<[quote="Mr. Wibbens"]Anyone ever get this fugger out easily?
Next time take and pack that hole flush with grease and find a bolt or round stock that fits tight inside the bearing and hit it with a hammer. Refill with grease after each hit. Two or three times and it's out.
All your doing is pressing the bearing out using the grease.
Used to do the same thing with pilot bearings and bushings.
