drowned bike
ez
drowned bike
anyone had this happen? my son droped his kx100 in a big mudhole only thing you could see was the left grip. would not restart. we got it down the mountain he cranked it ran a little. i stopped him. the oil was milky. i think the water went in the carb via the airbox. I have it all out dowm to the carb . drained the carb gas looked good let new gas in drained the oil put about half back in. rolled it over in gear with plug out.took the packing out of silencer(didnt seem wet i don't know how) i checked it has spark.I thought about spraying wd40 every where i could to remove moisture.i am about to try starting it.just wanting to know if there is something i am overlooking? this place is great for anything kawasaki or 2 stroke related. thanks
jumping is no problem however landing is another story
ecojbr
Change gearcase oil till its clean. Make sure as much water is out of cylinder/crankcase as possible. try to get the bike running as soon as possible. Removing the moisture is #1. A teardown would be preffered if possible as dirt/mud in the water will cause wear or even damage. had an outboard go under, got it running in just a few minutes and thats all it took, get fresh fuel/oil ran through the motor and will probably be fine
04 kx220 hybrid
03 kx 250
05 kdx 200
03 kx 250
05 kdx 200
- scheckaet
From what I've heard this is what should be done:
remove plug, carb, dry air filter as much as possible.
put bike upside down to drain water from pipe and silencer
kick it to get water out of cylinder
put everything back ride home.
Take everything down and do a thorough cleaning of carb, air filter, plug, change oil till it's not milky. done.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- scheckaet
oh I forgot, ;ast thing on the list:
atomic "dopeslap" to the kid...don't do it again
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- kdxmaniac
do you mean drowned,.......like this??
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
- scheckaet
dumazzz
That one must have been fun to get out...double atomic dope-slap is in order then
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- kdxmaniac
i was just tring to see if atv=jetski
.............i found out "NOOO!!", the hard way!
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
ez
yea pretty much like the pic and he stood there looking at it..dopeslap unnecassary pushing/dragging bike down 4 miles of mountain. might have done the trick.worse is it was only the 4the time he has gotten to ride that bike.now i am trying to figure out how long this resurrection should last .oh and i forgot to mention we traveled 2 hours to get there.rode 20 min.and sank it.wasted day,
gregp
One of the worst things about a severe dunking is that the water will flush all kinds of dirt particles from the air cleaner into the engine. These dirt particles will reek havoc on your piston, bore, and main bearings. Unfortunately, other than a complete tear down immediately following a drowning like that, the best you can do is get the bike running right away, to blow everything out. As previously mentioned, change the gearbox oil repeatedly, until the milkiness goes away.
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
gregp
- Tedh98
- Been thanked: 2 times
The water in that picture is almost clear compared to the mud hole my son submerged is little 60 in.
Muddy water made its way all the way into the crankcase. I repeatedly flushed the bottom end with premix until it came out clean. I still had a bad feeling about it and split the cases.
I was glad I did because there was still mud around the bearings. I'm sure that stuff would have dislodged at some point.
