KDX wont start!
Fatherof2
KDX wont start!
Post by Fatherof2 »
Hi Gang,
Bought a KDX last fall, and spent all winter taking her apart and fixing her up. Finally got her all back together tonight, and she wont start.
If I hit her with some starter fluid, she will fire for about 5 seconds and then die out.
Fresh gas, freshly cleaned carb, fresh oil, gas is on, new plug, kick starter is very firm.
Any thoughts? I am pretty bummed.
Thank you for any help,
David
Stuck float? Try laying it down on its side and see if gas runs out the vent lines. If it does try starting it. If it is firing on starter fluid (You should not ever use starter fluid) than it has to be in the fuel delivery or the timing would have to be WAY out of wack. Have you checked the plug? Is it wet or dry? It could be possible to be getting too much fuel and flooding out.
is the gas opened...
Fatherof2
Post by Fatherof2 »
Well, she finally fired!
Dont know what the deal was. Let her sit for a few minutes while I was thinking things over. Threw my leg over, gave her a kick, and viola!
Rode around the block a few times. Throttle response is not crisp. Lots of power, but she bogs a bit in the first three gears. Time to start to figure out what that is all about.
Thanks for the input guys!
D.
For God and Country......Geronimo, Geronimo, Geronimo!!
Has thanked: 30 times
Been thanked: 46 times
Go back and make sure your ground connections are clean and tight. If they aren't it can cause all sorts of weird little problems.
TWMOODY
Re: KDX wont start!
Post by TWMOODY »
Fatherof2 wrote:Hi Gang,
What all did you take apart and fix ?
kdub405
Post by kdub405 »
Sounds like some carb tunning is on the schedule
Ride on
Fatherof2
Re: KDX wont start!
Post by Fatherof2 »
TWMOODY wrote:>|<>QBB<
I greased and cleaned everything! I also had FRP do the suspension. I will post pics soon.
KDX4ID
Post by KDX4ID »
Might need a new carb. The PWK wears out with time/hours.
CURRENT FLEET
2008 KTM 990 Adventure...Alaska here I come!
2010 KTM 300 XCW... stop me before I buy again!
2005 KDX220... single track sweetie
2007 KTM 450 EXC... my baby
2008 KTM Superduke... Canyon Carver
1996 Honda 650L... GONE but not forgotten
http://www.friendsoftruckeetrails.org
Fatherof2
Post by Fatherof2 »
KDX4ID wrote:Might need a new carb. The PWK wears out with time/hours.
The bike has 16 miles on it, and is bone stock.
fuzzy
Post by fuzzy »
Ensure air filter is clean/oiled. Fresh gas....Mixed with regular old 2-cycle oil....Switch to full synthetic later. Read up here on jetting. I would suspect super-rich jetting, and that your top-end isn't broken in yet. Warm up fully, Go ride the crap out of it....Flogging it through the 'blubber' If it cleans up and gets a good bit better through the ride, your rings just seated well. :mrgreen:
KDX4ID
Post by KDX4ID »
Fatherof2 wrote:>|<>QBB<
Well there ya go... time for a new carb! :wink:
CURRENT FLEET
kdub405
Post by kdub405 »
Why take a bike with 16 miles on it all apert and fix it up? :shock:
Ride on
