KIPS Part Identification
sthutch
Post by sthutch »
I am working on my top end on my '01 KDX200 and was wondering what this part is, material it is made of, and use, beyond the identification by Kawasaki as "spacer." I have found it on the diagram (highlighted in yellow) but not in the parts removed.
Image[/img]
Thanks,
Sthutch
Sthutch
1st Bike: '72 Arctic Cat Whisker (rode it to the wheels fell off)
2nd Bike: '76 KT250 Trials (gone, but not forgotten)
3rd Bike: '01 KDX200
4th Bike: '96 DS80 (okay, my 9yr old's and it's gone)
5th Bike: '04 RM65 (okay, he's now 10 and it's gone)
6th Bike: '08 KTM 105xc (okay, he's now 13)
7th Bike: '06 KTM 200xc-w (okay, he's now 16)
I was just in there not to long ago and I do not recall that either.
gregp
Post by gregp »
Just a guess, but it looks to be a movement "restrictor", possibly for the European "S" version....
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
KarlP
Post by KarlP »
I wonder if that is the o-ring that goes on the RH subport shaft, right were the pointer for part # 46102A is pointing
sthutch
Post by sthutch »
I just check the Kawasaki site and I don't see the o-ring listed in the parts for the cylinder/head diagram. Has anyone ever replaced this o-ring? Would it dissolve if it soaked in mineral spirits for a week? I am feeling like an idiot because I already put the head back on.:oops: I don't remember seeing it, but it is illustrated plain as day in my manual. I don't know how I missed it.
Sthutch
KarlP
Post by KarlP »
You'll have to search around on here.
That "o-ring" is called packing. It does not come in a typical gasket kit. I bought some a few years ago based on information I got from this site. If you search past posts on my name you should find where I got the part number.
It won't hurt anything if you did not replace it. Soaking it in solvent for a week probably did not hurt it. It is there to discourage exhaust gases from going from the RH subport valve into that plastic cover on the RH side that has the claw gear in it.
I know you can't replace it without pulling the cylinder. The RH subport shaft will run into the frame before coming out all the way.
KarlP
Post by KarlP »
sthutch
Post by sthutch »
Great link! I wished I found it earlier. I ordered the part (#43049-1076) and a new head gasket. Anyone had any luck reusing a head gasket that has been tightened but not run?
Sthutch
It should be fine. I have never done it on a dirt bike but once or twice on a diesel with no problems. Just give it a good looking over and go from there. Any doubt and put in the new one.
Mr. Wibbens
Post by Mr. Wibbens »
I've copper coated and reused a few head gaskets, you should be fine
