Do I need a replate?
frankenschwinn
Post by frankenschwinn »
Some pics:
Can I get another topend out of this thing?
Needs plated....
kdxmaniac
Post by kdxmaniac »
from looking at the pics, i think you are about time for a replate. 3rd + 4th pics from the bottom.....looks like its pretty thin, and the lines look like border line..........but i cant say for sure from the pics. all i can say is, if it was mine, i would replate.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
BobbyZ
Post by BobbyZ »
my vote is replate...........granted it's tough to tell from the pics but IMHO this is one of those questions where if in doubt enough for most people to have to ask,it's usually time for it.
Mr. Wibbens
Re: Do I need a replate?
Post by Mr. Wibbens »
>|QBB<[/url]
frankenschwinn wrote:Some pics:
Is this before or after you hit it with a Scotchpad?
frankenschwinn
Before. It looks a bit better now. Measures within spec. Would be better to plate but It can go another shorter round. Replacing piston, rings and cleaning kips while its apart.
Has thanked: 10 times
Been thanked: 17 times
Good luck with it! You might need it.....
gregp
Post by gregp »
I don't know....that cylinder really looks "OK" to me. There are a couple of light scores, but nothing that would make me send it out right away unless I had money to burn, and/or I was seeking perfection. The plating looks to be entirely intact, and in good shape for the most part. I see no flakeing at all. Flakeing is pretty obvious when you see it. KX500's were famous for this, and I have seen several of them in bad shape.
I would clean it up, install a new piston and rings, and run it.
**JMO**
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
frankenschwinn
juliend wrote:Good luck with it! You might need it.....
hopefully it will get me through the divorce... Thats the main goal.
Cturbo
Post by Cturbo »
The cylinder looks OK. I would put a forged piston to mitigate the damage a less than perfect bore will do. My cylinder was worst than that two seasons ago and I still riding it. In my case I notice more piston wear than expected.
1992 KDX 200
2004 KLX 110
2006 SMR 510
Agree on the forged piston. I did a similar thing with the first top end on my bike. It was barely in spec, with wear on the bottom of the cylinder similar to yours. It destroyed a cast piston in short order. I took it out just in time. The skirts had started to develop stress cracks from piston slap after just a few months time.
frankenschwinn
I have a Wiseco piston kit in hand. I will not even attempt to argue the merits of not plating it now as I know that is the right thing to do. just can't do it right now if not absolutely necessary.
Varmint
Post by Varmint »
Mine had little grey lines like yours (see below) and I did not replate. I hope those little white linty things are actually lint and not marks.
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
frankenschwinn wrote:I have a Wiseco piston kit in hand. I will not even attempt to argue the merits of not plating it now as I know that is the right thing to do. just can't do it right now if not absolutely necessary.
It'll run.
Mr. Wibbens
Mine looked similar to the OP's before I hit it with the Scotchpad
I looked but I guess I did not take any before pics
Looks perfect Wibby!
Mr. Wibbens
It was a big surprise
But I'm sure I had bloody knuckles
Oh you know what I used? I used a scothpad sponge. It was easier and did not snag on the ports as bad
